Page 1 of 2
pm tuning pro street levers
Posted: Mon Sep 24, 2012 4:07 pm
by smoore-gt225
hi does anyone know or have fitted pm tuning pro street levers to a series 2
phoned pm tuning and they didnt know if they would fit :o
cheers steve
Re: pm tuning pro street levers
Posted: Mon Sep 24, 2012 5:24 pm
by RICSPEED
they wont .. you would need late indian clutch and throttle lever supports
Posted: Mon Sep 24, 2012 5:36 pm
by smoore-gt225
RICSPEED wrote:they wont .. you would need late indian clutch and throttle lever supports
hi thanks do you mean i would have to fit a indian gp type gear change support, i dont need the throttle side as got hydraulic fitted
cheers steve
Posted: Mon Sep 24, 2012 10:11 pm
by RICSPEED
indian gp -
http://www.ebay.co.uk/itm/LAMBRETTA-GP- ... 3f16641e6a
series 2 -
http://www.ebay.co.uk/itm/LAMBRETTA-LI- ... 5ae99b57de
ok compare the two ...you will see that the series 2 type (second link )is straight where the lever meets the housing where as the gp type is not ..fit the late indian type then you can fit the pm levers as i belive they do one for the nissin type m/c
Posted: Tue Sep 25, 2012 6:59 am
by soulsurfer
^^^ They're not a straight fit tho' as the handlebars are thicker on a S2 so these would need the inside opening up to slide over the handlebar.
Posted: Tue Sep 25, 2012 10:18 am
by Steve S2
Hi
You can fit them but you have done a little griding on them
Posted: Tue Sep 25, 2012 3:22 pm
by RICSPEED
soulsurfer wrote:^^^ They're not a straight fit tho' as the handlebars are thicker on a S2 so these would need the inside opening up to slide over the handlebar.
Yes you are correct .. I had forgot about that ... Then as above you need to cut to suit
Posted: Tue Sep 25, 2012 4:13 pm
by soulsurfer
Jason Frost suggests the Vespa ones should fit, is that right, the vespa lever is the same fit as a S2?
Posted: Tue Sep 25, 2012 5:17 pm
by Steve S2
Vespa levers do fit but you still have to some grinding.
Posted: Sat Sep 29, 2012 7:49 am
by smoore-gt225
hi i bought some of the scootrs atomic levers for the px vespa and they have fitted the series 2, no problems whatsoever :D
cheers steve
