has it been done before?
Posted: Mon Sep 24, 2012 11:42 am
by jackskater
right im looking at replacing all seals and bearings on my t5 this winter but whilst i had the casing aparts i was looking into porting the cases and barrel and fitting either a 26 or 28mm dellorto phbh carb, ive been scouring the web and cant find any info anyone else doing this, as i like the idea of keeping the standard 125 kit and i cant really justify spending loads on a kit atm
Re: has it been done before?
Posted: Mon Sep 24, 2012 11:57 am
by Ian Hepworth
Putting a big carb on it's own will do nothing but put your petrol bill up.
The standard carb is fine for 99% of applications.
Casings don't need matching on T5s they are good as is.
Posted: Mon Sep 24, 2012 12:02 pm
by gimp1971
if you open exhaust port i think that gives you a bit extra and a decent pipe
Posted: Mon Sep 24, 2012 12:07 pm
by jackskater
speaking to a mate last night that does sprinting and hes reckons that a dellorto phbh carb or similar will provide better throttle response and slightly better top end, surely fuel consumption wouldnt change if i fitted a a 24mm carb in this style as the standard is 24mm
