When cold, cough, splutter, misfiring etc
Posted: Sat Sep 22, 2012 8:52 pm
by a.j
Then runs fine after a minute when its warmer. Also hit a heavy pothole today and it misfired then too, whether there's any connection I dunno..
Any ideas gents?
Re: When cold, cough, splutter, misfiring etc
Posted: Sat Sep 22, 2012 9:21 pm
by Andy Pickering
Sounds like ye got man flu fella ;-)
Posted: Sat Sep 22, 2012 9:41 pm
by Mel K
Make the most of it and get on the couch, for at least a week.
Posted: Sun Sep 23, 2012 8:52 am
by purple_pill67
Couple of paracetamol and a cuppa should help
Posted: Sun Sep 23, 2012 9:03 am
by a.j
Ha ha ha You guys are CWAAAAZY!
Posted: Sun Sep 23, 2012 9:46 am
by bristolmod
the fact that it happened when you hit a pothole indicates that there is a fine break/ loose connection somewhere.
Work back from the sparkplug- is the cap on tight? Is the screw on bit on the plug done up tight? Electronic or points? Are all wires on junction boxes/ ignition switches tight and secure? Dry/ loose joints on stator?
Process of elimination I'm afraid
Posted: Tue Sep 25, 2012 3:53 pm
by a.j
bristolmod wrote:the fact that it happened when you hit a pothole indicates that there is a fine break/ loose connection somewhere.
CHEERS MATE. i WAS FEARING THE LONG WAY ROUND.
Posted: Tue Sep 25, 2012 8:09 pm
by Starwave
Had a similar prob some years back when the scoot would misfire occasionally, but always when I dropped myself hard onto the seat. Turned out to be the back of flywheel catching on the green ignition wire. But I suppose any loose connection or ignition wire with missing insulation would give the same symptoms?
