Round junction box
Posted: Wed Sep 19, 2012 7:25 pm
by jamjo
Hello all, wondered if anyone had any info about getting rid of the round junction box on the gp and can I just wire straight from the stator to the cdi and regulator without using one . As long as I introduce earths will thi be ok
Thanks in advance James
Re: Round junction box
Posted: Wed Sep 19, 2012 11:59 pm
by rosscla
Your green, red and white go to the cdi and the yellow to the reg, the out put from the reg then needs to feed power to the loom, usually a black a brown and a purple.
The cdi should be earthed independent of the white, which is also an earth connection to the stator.
The reg should be earthed.
You can just tape all the wires together including the feed from the regulator.
Better is to get one of the early Indian DC ones from SR, all connections are cross connected except the greens for the ignition switch.
