JL3 issues
Posted: Wed Sep 19, 2012 6:25 pm
by retrorich
I know this issue is a trade off for having a expansion type system but is there a way of stopping the endcan from repainting my panel with exhaust crap? Situation has gradually got worse over time and oil is seeping through the riveted bands on both ends of the can. It does this on low and high RPM. Other JL3 users do not seem to suffer the same degree of oil splatter over their panel as mine and they do more miles than me. Exhaust is over 18 months old and covered 2000 miles.
Re: JL3 issues
Posted: Wed Sep 19, 2012 7:13 pm
by coaster
How much oil are you putting in there? I usually run at 3% but ran it at 4% whilst running in my Avanti and although there is some oil seepage around the rivets, it certainly isn't bad :?
Re: JL3 issues
Posted: Wed Sep 19, 2012 7:22 pm
by camel
is it coming THROUGH the rivets?ive put a dab of araldite on pm tailpipes rivets in the past and used high temp silicone on the slipjoint of my ads 3 im currently using....its a leak at the end of the day so find it and block it
Re: JL3 issues
Posted: Wed Sep 19, 2012 7:52 pm
by sydduckett
I have had this problem on my franspeed race from both rivets and the slip joint. If its coming through the rivets then its only a matter of time befor they start popping out. Your best bet is to drill them out and re rivet them before the holes they sit in widen which they will. If your lucky you may get away with using the same size rivets if not you will need to re drill and put the next size up in. I have had to do mine twice now.
As prev said best fix for the slip joint is the rubber sleeve, think Beedspeed do them for £8
sef
Re: JL3 issues
Posted: Wed Sep 19, 2012 8:51 pm
by bazman
How rich are your carb settings does your scooter splutter or 4 stroke at all?
Re: JL3 issues
Posted: Thu Sep 20, 2012 2:16 pm
by shocky
i always use clear silicone when reassembling endcans and slip joints just wipe of the excess it will slow down the time it takes to leak and might even stop it
