Page 1 of 2
Motovespa GT160 side panels ?
Posted: Mon Sep 17, 2012 2:03 pm
by mushroom
I picked up a GT160 last week and it came with some side panels that don't fit it.
They are the right length but have the long rectangluar clip that fits into the U shaped bracket on a different frame. (My Black 2000 Bajaj frame for instance )
The GT has similar brackets to P200
The left hand side panel is removeable with a spare wheel stored underneath
Are these panels particular to the GT or which ones should I be looking out for ?
Re: Motovespa GT160 side panels ?
Posted: Tue Sep 18, 2012 7:46 pm
by Fruitjuice
Some models of GT160's have the same side panels as the italian GS160's.
Which is why they're probably not on the bike anymore....
Luckily for you they're available and affordable as repros now!
Posted: Tue Sep 18, 2012 8:14 pm
by mushroom
Fruitjuice wrote:Some models of GT160's have the same side panels as the italian GS160's.
Excellent, that's just what I wanted to hear, cheers
Posted: Tue Sep 18, 2012 8:45 pm
by gavi4t
get an old pair of p range panels and drill out the spot welds from the spring , with a little effort they can be welded onto your panels instead of the clip ,ive done this a few times in the past saves time and money looking for panels
Posted: Tue Sep 18, 2012 8:49 pm
by mushroom
Left hand one is a bolt on one though
Thinking of selling these 3 side panels ( 1 left and 2 right) and just getting the repro GS ones instead
Posted: Wed Sep 19, 2012 12:00 pm
by Fruitjuice
The left hand side of the frame shouldn't require a bolt-on side panel. It should have the same mounting clip welded as on the right side...
Posted: Fri Sep 21, 2012 8:21 am
by panamesc
gt panels are similar (but not exactly) to the rally panels with the same fittings than the rally and P range
and the spanish "gs" panels are NOT the same !
Posted: Fri Sep 21, 2012 9:11 am
by mushroom
So would Italian GS panels fit ? Or do I need specific Spanish GT panels ?
Posted: Fri Sep 21, 2012 5:16 pm
by gavi4t
i have an early 150s which has gs160 mk2 panels which has clips both sides , if you wanted clip on panels both sides you would have to weld on a spring hanger onto the frame , am i right in thinking your frame is similar to a 150 super with a toolbox left hand side panel ?
Posted: Fri Sep 21, 2012 7:44 pm
by mushroom
gavi4t wrote:i have an early 150s which has gs160 mk2 panels which has clips both sides , if you wanted clip on panels both sides you would have to weld on a spring hanger onto the frame , am i right in thinking your frame is similar to a 150 super with a toolbox left hand side panel ?
No it has a spring hanger on both sides, similar to a P2
