Comparable jetting Pinasco 225, JL pipe, 28mm PHBH
magg
Main scooter: Vespa GL 225
I'm looking for someone with the same setup and I'd like to compare jetting.
Can't really find a comparable setup in the jetting section, so I'm trying here as well.
I'm running a 125 main, AV264, X2 needle top clip, 58 idle, 60 slide, 1.75 turns out on the idle screw.
