Help with a repair in N. London/Herts please
Posted: Mon Apr 20, 2009 11:20 am
by ukoldschool
Can anyone reccomend somebody local (ish) to repair my hub please? It needs a crack welding up and a reverse thread helicoil fitted :baddevil:
If now local then is there somebody trusted I could send it to for repair?
cheers!
Re: Help with a repair in N. London/Herts please
Posted: Mon Apr 20, 2009 11:41 am
by shocky
as a welder i wouldnt touch someones hub, ive been asked to weld disc hubs in the past and refused what hub is it
Posted: Mon Apr 20, 2009 11:58 am
by ukoldschool
Original inboard disc, window side. small hairline crack where the remains of a stripped hub stud refused to come out.. I was thinking a simple slot through the crack then weld up and I could shape it to suit? then get a helicoil fitted afterwards. The actual lug is still exactly as before.
Posted: Mon Apr 20, 2009 1:35 pm
by Daggs
Instead of faffing about with a left-handed helicoil, if such a thing exists.
How about welding up the crack and hole (ooh errr!!!) then redrilling and tapping it. Possibly to take a standard 8mm setbolt.
I know it won't look pucker, but it may well be stronger.
Posted: Mon Apr 20, 2009 1:56 pm
by ukoldschool
hmmm.. clearance problems on the rear?
Posted: Tue Apr 21, 2009 7:06 pm
by Timbo
I know a top class welder at Letchworth, scooter man.......
Posted: Tue Apr 21, 2009 11:28 pm
by monkey boy
Why not use the press fit studs??
Gotta be easier than trying to sort out the thread..
MB sell them
CHEERS AL
