P.H.B.L advice
Posted: Fri Sep 14, 2012 8:45 am
Hi all,after hearing good things about the 25mm PHBL carb,i have decided to give one a try on Mrs Kevspeeds scooter.The engine spec is tv 175,stage four barrel,42mm VW clubman,Italian Li 150 gearing,Indian electronic set at 19 b.t.d.c.
Im after some jetting suggestions for the carb to run using one of the MB airhose/foam filter set ups.Thanks in advance...............Kev.
At the moment im trying out a 95 main,44 pilot,50 slide,D26 needle,AQ266 atomizer
I have tried out a 98 main,50 pilot,50 slide,D36 needleAQ266 atomizer,but with both set ups its been a t**t to start till i remove the filter.
