mugello oil mix
Posted: Sat Sep 08, 2012 2:15 am
by roy242
hello, in the month of November I have thought a trip kmts approximately 6000.
I am currently using on my mugello motul 710 (synthetic) .. well, in some parts of northern Argentina will not get that oil or other synthetic .. what could happen if I use semi synthetic or mineral oil in Mugello?
thanks!!
Re: mugello oil mix
Posted: Sat Sep 08, 2012 7:07 am
by soosh
It will keep going as normal.
Re: mugello oil mix
Posted: Sat Sep 08, 2012 8:37 am
by coaster
No problem at all, I used to run mine on whatever synthetic or semi-synthetic I could get. Never had any trouble with mixing even on the odd occation where I had to use mineral oil in over 4,000 miles.
Re: mugello oil mix
Posted: Sat Sep 08, 2012 6:38 pm
by gerryjunior
been running my rapido on minerial oil since i built it , about 4000 miles now , no heat seizures , never had aproblem and i drive the knob out of the poor thing,
Re: mugello oil mix
Posted: Thu Sep 13, 2012 6:51 pm
by Donnie
I would not advise mineral oil on a mugello personally, yes you can use it on any engine but it's very nature is that it's fairly hard on the internals, that's why it's great for running in the first few hundred miles of a cast iron barrel / lined barrel.
Personally I always recommend semi for cast iron barrels, fully if you want it on cast, and would always use fully on say imolas and ts1s.
The danger here if doing such a trip is mixing your oils, you can easily get away with a mix of semi and fully in a tank, eg, on reserve with fully synth, top up 5/6 litres and mix with semi or vice versa.
However you won't get away with that mixing with mineral oil, you're asking for a seize :-(
Re: mugello oil mix
Posted: Mon Sep 17, 2012 5:30 pm
by roy242
thank you very much for the answers!
Re: mugello oil mix
Posted: Tue Sep 18, 2012 10:02 am
by dapper
Have a great trip Roy and take lots of photos and post them on here. I'd love to see Argentina, especially on a scooter. :D
Re: mugello oil mix
Posted: Tue Sep 18, 2012 10:07 am
by stokky
6000 kilometers.........I'd be more worried about state of my arse !!
But like the others say, would be really interested to know how you get on
