Page 1 of 2
cable routing for reverse pull disc set up
Posted: Fri Sep 07, 2012 6:58 pm
by Supereibar
Evening chaps, just wonder if the cable should go in front of the steering column or behind it? :?: I realise that it could be placed either way, however my concern is the clearance off the weel. I also realise that the cable needs to be hold by the coat hanger thingy that I need to fabricate...
Kind regards,
Jaime
Re: cable routing for reverse pull disc set up
Posted: Fri Sep 07, 2012 9:24 pm
by victor
I fitted a cable holder professionaly made, laser cut, but found it to keep the cable in a slightly wrong angle.
So instead i fitted the cable to the fork at the center of the wheel using a very loose zip tie. If I remember I can take a photo of it...
Posted: Fri Sep 07, 2012 9:36 pm
by RICSPEED
if i recally correct jason frost does a nice lazer cut cable guide/support i think though you will need dampers to attach to top stud (im assuming this is for your jet btw so on probs there ) cable i would expect to be in the same place more or less certainly at the head set end
Posted: Fri Sep 07, 2012 9:41 pm
by victor
RICSPEED wrote:if i recally correct jason frost does a nice lazer cut cable guide/support i think though you will need dampers to attach to top stud (im assuming this is for your jet btw so on probs there ) cable i would expect to be in the same place more or less certainly at the head set end
That's the one I got, looks the piece but didn't work well (for me). Probably others have had better results...?
Posted: Sat Sep 08, 2012 9:00 am
by Supereibar
I am still confused about the routing.. So should I place it in front of the steering column or behind it?
Posted: Sat Sep 08, 2012 10:12 am
by victor
I'll take a photo later, think only one way works though...
Posted: Sat Sep 08, 2012 10:49 am
by Supereibar
Thank you, I am doing a dry build of the entire system, I need to know the precise length of the cable and it is imperative that I route it correctly before doing any cutting...
Posted: Sat Sep 08, 2012 3:14 pm
by victor
Look at my Flickr account, youll find it in my SS 180 resto thread
Posted: Sat Sep 08, 2012 4:15 pm
by RICSPEED
victor wrote:Look at my Flickr account, youll find it in my SS 180 resto thread
will need a link mate
Posted: Sat Sep 08, 2012 7:54 pm
by twin
i have just done one and put it behind
