Varitronic regulator, DC out question?
Posted: Fri Sep 07, 2012 1:18 pm
by Robi D
I'm running a varitronic in AC (no battery) on my TS1. I'm going to be running a GPS speedometer. I was told that I'm good to go with setting up the speedo with the DC power out from the regulator. My question is, does the wire from the stator (red/white to charge battery) need to be plugged in in order for the power to be fed to the DC out?
Thanks
Re: Varitronic regulator, DC out question?
Posted: Fri Sep 07, 2012 8:58 pm
by wack 63
Yes
http://www.lambretta.co.uk/downloads/vari1.jpg You may also find there will not be enough power (trickle charge only) to run the speedo so you will need to fit a battery or capacitor to hold the speedo memory if it has one.
Posted: Fri Sep 07, 2012 9:02 pm
by Robi D
Good, I have a capcitor with 10,000 mfd, 100 vdc.
Thank you.
