What causes..........
Posted: Mon Sep 03, 2012 7:05 pm
fuel to accumulate in the carb air-hose?
Standard 1962 TV175 S3 apart from electronic ignition and a 42mm Clubman (main jet is now 108 instead of 106).
Recently, starting when warm has been problematical and I have carried out the following:-
1) changed standard 20mm Delly to an identical spare (same jets; slides; atomiser etc) no difference.
2) new plug- no difference; good spark on both
3) checked fuel flow thru tap- good
I have noticed that the air hose does accumulate fuel from somewhere, and removing said hose does allow the bike to start first kick when warm.
The hose is the "old type" with the drainaway system on the end and the metal perforated plate at the bottom.
Any ideas as to why fuel is collecting gents?
Was rebored 2000 miles ago; piston is standard oversize with no skirt removed on inlet side.
When bike runs it runs very well indeed- just a pig to start when warm, which I firmly believe is down to the excess fuel.
Any suggestions welcomed
Chris
Chris
