Wheel nuts
Posted: Sun Sep 02, 2012 8:18 pm
by sparklymarkly
Quick question please chaps:
I'm using nyloc wheel nuts to bolt my standard rims together & to hubs.
Should I use flat washer, spring washer, nyloc or leave out the spring washer and just use a flat washer & a nyloc?
Cheers.
Re: Wheel nuts
Posted: Sun Sep 02, 2012 9:19 pm
by andy66
On my lambretta the studs aren't long enough to use Nyloc and spring washers so I don't bother with a washer at all.
I check em everyday....on all my scoots.
Re: Wheel nuts
Posted: Sun Sep 02, 2012 9:43 pm
by paulmgreen
Nylon & flat washer I'd say. :)
Re: Wheel nuts
Posted: Sun Sep 02, 2012 10:07 pm
by red
I use 'Nord-lock' washers as they are less likely to work loose and also use shallow depth nyloc nuts.
Also use these on cylinder head studs
Re: Wheel nuts
Posted: Sun Sep 02, 2012 10:10 pm
by red
For further info on Nord Lock have a look here
http://www.nord-lock.com/
Re: Wheel nuts
Posted: Sun Sep 02, 2012 11:39 pm
by sparklymarkly
Cheers all :fb:
I'll ditch the spring washers & have a look at these NordLocks as well.
Thanks.
Re: Wheel nuts
Posted: Mon Sep 03, 2012 8:37 am
by andy66
I use Nordlock washers on my sip tubeless.they seem to be doing the job.
With all the stories about loose wheel nuts lately I'm suffering from wheel nut paranoia..
I never used to bother before,but I ALWAYS use my torque wrench now aswell
