Mugello 186 piston shims
Posted: Sun Sep 02, 2012 5:17 pm
by jrm
Regarding fitting mugello 186 kit,i've fitted new crank & bearings am on to piston.Do i need to fit piston shims as there is quite a gap between small end bearing & piston(approx 3-4mm).The crank is not shimmed.
Re: Mugello 186 piston shims
Posted: Sun Sep 02, 2012 5:30 pm
by byron
how much sideways movement of the rod is there at the big end ?
Posted: Sun Sep 02, 2012 5:38 pm
by jonnyb
Might be worth buying a wider small end bearing assuming your crank is shimmed, Cambridge lambretta have them in stock I think
Posted: Sun Sep 02, 2012 5:40 pm
by Gazbo72
jrm wrote:Regarding fitting mugello 186 kit,i've fitted new crank & bearings am on to piston.Do i need to fit piston shims as there is quite a gap between small end bearing & piston(approx 3-4mm).The crank is not shimmed.
Doesn't using shims or not depend on the crank that your useing ???
Posted: Sun Sep 02, 2012 5:42 pm
by jrm
Thanks 4 replying Byron.Just measured 1.3 -1.4mm.
Posted: Sun Sep 02, 2012 5:48 pm
by Gazbo72
My last post sounds a bit daft . I have just fitted a GP200 crank with the large gap at the little end bearing. Reading sticky's book it says this type of crank doesn't need shims.
Posted: Mon Sep 03, 2012 5:23 pm
by jrm
BUMP
