Ive almost finshed building my engine, im after advice on which sprockets would give the best result.
Im not interested in top speed as I mainly use it around London and for touring (luggage / hills etc.), it currently has a 16 front x 46 rear arrangement.
Would swapping the front sprocket (and chain) for a 15 give me the better touring option, easier into head wind and up hill etc.
Its running the following:
Imola kit.
60mm BGM crank
GORI exhaust
Varitronic
LI150 pacemaker gearbox
3.50x10 tyre
28mm del
Imola sprocket advice for touring... 46-15?
- lammysilver
- registered user
- Contact:
- corrado
- Dealer
- Main scooter: Lambretta GP
- Contact:
16 x 47 works well, that's 5.4 final drive, Imola works best at high revs. Hills and headwinds weren't an issue when I ran that gearing [with the pacemaker g.box].lammysilver wrote: Im not interested in top speed as I mainly use it around London and for touring (luggage / hills etc.), it currently has a 16 front x 46 rear arrangement.
IMO the Imola doesn't like top gear with anything taller than 5.2, and even then the exhaust choice is critical.
