Page 1 of 2
nylon bush
Posted: Sat Apr 18, 2009 9:34 pm
by gideon
Just fitted new nylon bushes to my fork links but they are to tight to put the metal pivot bushes through ,has anyone else had this problem , and how did they overcome it?
Re: nylon bush
Posted: Sat Apr 18, 2009 9:41 pm
by Knowledge
I bought a lathe and made my own bushes, that's how I overcame it.
You can use a reamer to remove some of the ID from the bush.
You can use the jaws of a vice to push the metal sleeves in, but there should be some movement here. If they are too tight, it is not ideal.
You could send the bushes back and ask for some that fit.
Re: nylon bush
Posted: Sat Apr 18, 2009 9:46 pm
by sean brady scooters
the white ones always seem a bit of a knightmare............the grey type a bit less so...........
black ones seem quite good from my experience so far.........but i,m sure other folk may see things differently...........
knowledges solution is the best in this respect......................
Re: nylon bush
Posted: Sat Apr 18, 2009 9:51 pm
by rog60
IMO fitting link bushes ranks equal first with trying to get the 'bridge' piece to fit neatly.
Re: nylon bush
Posted: Sat Apr 18, 2009 10:10 pm
by shocky
i use brass ones with a spiral groove in them for the grease ,the links need to move freely when everything is tight , i trial test mine before i fit the springs and rods i susspect that if one link is tight thats why people scoots pull to one side esp when braking
Re: nylon bush
Posted: Sat Apr 18, 2009 10:52 pm
by storkfoot
I've had this problem with the white ones. I binned them and bought a set of black ones from MB which were, by comparison, almost finger push in.
Re: nylon bush
Posted: Sat Apr 18, 2009 11:51 pm
by gideon
its the white bushes im having trouble with. i pushed the metal bush in halve way with a vice but gave up when i realised there wasnt going to be any movement
Re: nylon bush
Posted: Sun Apr 19, 2009 9:13 am
by mark
send them back and spend a little more on the mb ones .
Re: nylon bush
Posted: Sun Apr 19, 2009 9:57 am
by Muttley McLadd
I've helped fit a set from MB. Half an hour with some 80 grade sandpaper to get them to fit.
Re: nylon bush
Posted: Fri Apr 24, 2009 3:59 pm
by gideon
ive just tried mb bushes still impossible without vice i think i need a reamer can anyone help with what size i need price etc thanks
