Monza Short Manifold needed...
Posted: Sat Apr 18, 2009 9:34 pm
by J1MS
Does anyone know which is the shortest manifold to fit under the panels on a monza 225 with a Dellorto 30mm Carb fitted....... Thanx ..........
Re: Monza Short Manifold needed...
Posted: Sun Apr 19, 2009 6:42 pm
by corrado
"jimmers" manifold will give you the most clearance but you'll need to PM him to see if he does a bolt on rubber for a 30mm carb. I have the manifolds but only have the 35mm rubbers.
