Mk 1 px toolbox on an EFL frame
Posted: Mon Aug 27, 2012 3:54 pm
by wink
Hi all, can anyone tell me if the thinner doored mk1 toolbox will fit on an older 1984 frame. Just fitted one and it seems a touch small. Cheers wink.
Re: Mk 1 px toolbox on an EFL frame
Posted: Mon Aug 27, 2012 4:34 pm
by mark1
It will fit but will need a bit of fettling. the cut out which fits in to the steering column bit is different but will fit.
I think you will also need to drill 2 holes in the frame.
I've just fitted a mk1 toolbox to a T5 classic, it only took about half an hour. great fun with the grinder though lol
Posted: Tue Aug 28, 2012 7:53 am
by wink
Cheers Mark1, have you any idea how much I've got to trim off and is it from both the top and bottom?
Cheers Chris
Posted: Tue Aug 28, 2012 9:44 am
by mark1
The bottom should fit ok. you dont have to take much off. Prob about 5mm.
Put some masing tape around the steering colum / ignition lock but on the frame to protect the paint and place the tool box on to see where and how much you need to remove. Its just a case of file a bit, try, file a bit more until your happy with the fit.
