fuel miles ?
rbgaz
after bit of testing worked out i get 9.33 miles to the ltr and 111.96 from full 12ltr tank this is on a rb22 and was wondering what others get to compare if this is good bad or average p.s this was town riding so would expect more on long motorway rides
bizzly
Thats good. I usually get 10 mile per ltr solo riding and 7 when Im 2 up on my ts225
red
I get between 24-26 mpg on my TS1 230 ;)
cev
What setup are you running rbgaz? I get nearer to 7 with mikuni and nk. Its great for long distance runs but a bit of a shock when I fill up the 17l tank!!
Mel K
I get just over 10 miles per liter , full bodied series 2, ts1 225, 58 mm crank, 32mm vhsa pacemaker gearbox and Taffspeed exhaust,. 20 stone with all my gear on and 6' 4" wind resistor. :oops:
purple_pill67
Main scooter: Jet200
Before i changed from Jetex 22/Casa twin to PHBH30/new style AF I used to get about 90miles to 5L...thats on a SR200.
victor
Main scooter: Tv175 but currently a SS210 :)
Tv 175 s3 standard besides Gori Sport:
6.23 l / 100 km => 16 km / litre equals almost 115 km between pitstops...
But I only run full open throttle, same consumption in London as on A roads...
rbgaz
cev wrote:What setup are you running rbgaz? I get nearer to 7 with mikuni and nk. Its great for long distance runs but a bit of a shock when I fill up the 17l tank!!
hi cev mines a 230 with super monza piston with tm35 and franspeed race no tuning just bolt on kit
cev
Cheers rbgaz. I suspect I may have a problem with the choke not sealing properly on the tmx. Its a real pig to set up the midrange.
