Fork fitting woes.
Posted: Tue Aug 21, 2012 1:10 pm
by psychedelicropcircle
I have fitted the bearing cone at the bottom and inner piece then as I try to slide the forks up the frame tube the metal flat bar that is welded on at the top (steering lock related I think) of the forks doesn't go past the bearing cone at the bottom.
HAVE I
A. Fitted the inner piece in the bottom bearing cone too soon and needs to be removed?
B. there's is no B :wtf:
Also fitted the chrome ring should I have done this after the forks :wtf:
Re: Fork fitting woes.
Posted: Tue Aug 21, 2012 2:02 pm
I can confirm that;
That when knocking out the bottom cone many months ago I have put the inner piece that sits in the chrome ring inside the bottom bearing cone.....and then refitted it :barfy: must have been trying to keep em together.
Sorry for the confusion folks...this has to be a first and one of the finest feck ups :bigsm:
Posted: Tue Aug 21, 2012 7:15 pm
Can someone tell me is it this piece that fits inside the chrome ring ?
Posted: Tue Aug 21, 2012 7:18 pm
If so where does these go?
Thank you in advance.
Posted: Tue Aug 21, 2012 10:57 pm
by goldeneye
Scott, they look like cock rings ...you sure you"ve went to the right shop mate?
Posted: Wed Aug 22, 2012 6:27 am
by Toddy
Posted: Wed Aug 22, 2012 2:03 pm
so wot yer saying is somebodies cockring has to go inside yer chrome ring
...well youd nar having done this before jef :freak:
Posted: Wed Aug 22, 2012 6:03 pm
by dapper
psychedelicropcircle wrote:If so where does these go?
That's the top steering bearing race and the bearings that sit on it before first locking ring then tabbed washer then final locking ring
Posted: Thu Aug 23, 2012 10:17 am
by lambytone
This is the top race and bearing that goes into the top of the chrome ring, the other picture I can't make out, sorry.
