GP Chaincase side question?
Posted: Sat Aug 18, 2012 3:18 pm
by servetakid
Ok , i decided to upgrade to a GP chaincase side on my Jet as the clutch fimble had started to wear quite badly. But the question is, do i have to use a GP endplate? the way i read it in stickeys book is no, and i cant tell any differrence on that part of the kick start shaft. But just wanting to double check.
Thanks once again!
Re: GP Chaincase side question?
Posted: Sat Aug 18, 2012 3:23 pm
by Mag
Later GP side casings dont have the 3 holes for the kickstart retractor drilled and tapped. If they are tapped or you can get it done you're ok, if not you will need the GP endplate,
Posted: Sat Aug 18, 2012 4:00 pm
by servetakid
Yes i realisewd the holes werent there just after posting this, haha. Would it be worth getting the holes tapped? I believe the earlier system is better is it not? Thanks
Posted: Sat Aug 18, 2012 5:57 pm
by 10 inch Terror
servetakid wrote:Yes i realisewd the holes werent there just after posting this, haha. Would it be worth getting the holes tapped? I believe the earlier system is better is it not? Thanks
I drilled and tapped the holes myself. Very easy to do and yes the earlier system is better than the later one.
Posted: Sat Aug 18, 2012 9:18 pm
by rosscla
Ditto ... Just did mine like that, the casting is ther to guide you as long as you drill them straight and deep enough... measure the depth of the holes in your old casing
Posted: Sun Aug 19, 2012 3:41 pm
by corrado
rosscla wrote:................. as long as you drill them straight ...........
I'd better not attempt it then.
Have a seen some sort of tool / template somewhere for this specific purpose?
Posted: Sun Aug 19, 2012 7:15 pm
by MarkH
15 minute job. Very easy to do.
You need a 5mm drill bit and a M6x1.0 tap. The template is right there on your GP crankcase cover. Take the depth measurement from you old case, dot punch the center of each hole to be drilled on the GP cover, drill each hole to depth (can be done with a hand drill if you have a somewhat steady hand), remove debris, tap and thread each hole.
Done.
Posted: Sun Aug 19, 2012 9:04 pm
by servetakid
Ok, sounds like the best way to go. But how tight should a new kickstart shaft be? The original one just slides in and out of the original casing, but the new one does not want to go in the new casing? I've tried to avoid using shear force...
Posted: Sun Aug 19, 2012 10:33 pm
by rosscla
I think you might want to edit that....
Posted: Sun Aug 19, 2012 10:58 pm
by servetakid
Ooops...
