Mag Flange Fit
Posted: Tue Aug 14, 2012 11:09 am
by Gazbo72
Just after a bit of info really. Should the mag flange be a tight fit. When stripping the engine the threads for reomaval where knackered so I had to tap it out with a mallet. It come out ok with no damage and the only one thread for the cowlings that was knacker which I have drilled and retapped and know ok.
I am going to retap the threads to the next size up for removal in the future but after cleaning the casing and mag flange I tried them for fit anf it is quite a tight fit is this right ???
Sorry if daft question :oops: but just wanting it right before i start the rebuild.
Gaz.
Re: Mag Flange Fit
Posted: Tue Aug 14, 2012 11:25 am
by DigDug
If it came out it should go back in - just make sure all is clean and free of burrs.
Re: Mag Flange Fit
Posted: Tue Aug 14, 2012 11:54 am
by dapper
What Digger said and put a smear of grease around the outside to help it slide in and also helps to seal it too.
Re: Mag Flange Fit
Posted: Tue Aug 14, 2012 2:32 pm
by Gazbo72
Thanks for the replys. Just retapped the knackered threads for future removal .
Now ready to fit the new bearings. I could be gone some time :D
Re: Mag Flange Fit
Posted: Tue Aug 14, 2012 3:46 pm
by rosscla
Put it in a poly bag while you fit the big circlip...will save you picking it out of the four corners of the garden
Re: Mag Flange Fit
Posted: Tue Aug 14, 2012 6:30 pm
by Gazbo72
Woohoo new bearings and crank is in with out having to leather it with hammer :D
Is it better to use nylocs on the 3 bolts that hold the mag housing on. Or will that cause problems with the flywheel later ????
Re: Mag Flange Fit
Posted: Wed Aug 15, 2012 9:56 am
by dapper
I've used nylocs without issue and even put SS wavy washers under them for good measure.
Re: Mag Flange Fit
Posted: Thu Aug 16, 2012 8:47 am
by Special X
For Uber safety why not use thin nuts with nordlocs :mrgreen:
