PWK info required
Posted: Sat Aug 11, 2012 4:32 pm
Hi there. I found this up in my garage roof and thinking of using it on a 200 alloy top end on a S2 li150 case The only problem is I have never used any other carbs apart from sh dellortos and jetex
So here goes. Is the top arrow pointing to the power jet. Is this any use on a lammy engine ??? I think the middle arrow is for a 2 stroke injection system and can it just be plugged. Is the bottom arrow for feeding the power jet.
The bits inside I have found. The slide is marked *35, Slow jet is *38 and the needle is N68A. Are these any use for my application. There is no main jet in it. will it use round or hex main jets ???.
Sorry if these are daft questions
