Leaking fuel..spaco PHBM 30mm
Posted: Sat Aug 11, 2012 3:48 pm
by clockwork
HELP...PLEASE...Just finished putting the finishing touchs to my scoot a Lambretta 150, I decided to give her a test run after having had no problems running it in the garage
, only got to the end of the road and it cut out better sooner than later i thought
got back to the garage to have a look noticed on the carb which is a spaco PHBM 30MM (P6504) on the left hand side of the carb a severe fuel leak first thing i thought float chamber loose but that was ok the leak was coming from higher up? talking to somone about it they said sticking float, this is the overflow
Has anyone got any ideas beside sticking float?
Cheers all
Re: Leaking fuel..spaco PHBM 30mm
Posted: Sat Aug 11, 2012 4:32 pm
by RICSPEED
if float sticking .. will just keep filling and over flow .. i wouldnt recomend a spaco personally but check alls well in the movement of the float
Posted: Sat Aug 11, 2012 4:35 pm
by clockwork
RICSPEED wrote:if float sticking .. will just keep filling and over flow .. i wouldnt recomend a spaco personally but check alls well in the movement of the float
Thanks for that mate will check it
Posted: Sat Aug 11, 2012 5:08 pm
by clockwork
Just one before i go mate ...you said you wouldnt recomend a spaco it came with the scoot what would be a straight swap?
had it dynoed at chiselspeed my jet sizes are main 120....pilotb55.....slide 40
thanks again mate
Posted: Sun Aug 12, 2012 2:35 pm
by clockwork
clockwork wrote:HELP...PLEASE...Just finished putting the finishing touchs to my scoot a Lambretta 150, I decided to give her a test run after having had no problems running it in the garage
Cheers all
Spot on advise sticking fload sorted now thanks...........
