RACING INLET RUBBER
mickdale
what is the "bellmouth" style rubber/plastic inlet thats used on the carbs for racing
is it off a gillera?
anyone know the diameter?
assume its ok to cut a hole in the panel on group 4
cheers
mick
wack 63
Main scooter: '71 GP TS1
Got one on the Team DKS group 4 but not sure what it is off,try ringing Chalkie at Replay . Image
paulmgreen
Commonly used ones re from an Aprilia..... As above Chalky at Replay will sort you out . What carb are you running?
www.JPPLambretta.co.uk
mickdale
hello paul
30mm vhsh carb at the mo but will probably change
sorry to ask a stupid question:
regs say no modifications to headset but assume its ok to cut a hole in the panel for group 4 and cut the rear runner a bit for brake pedal in non stanard position
also ok not to use rear frame grille and rear light housing - if this is ok is it ok not to run hornacst grille?
cheers
mick
paulmgreen
I assume you are talking about Gp 4 ?...
Holes to suit carb are ok in side panels.... As are for rear set.... They can't be huge though .... Just enough for clearance !
The real light housing and horn casing grill need to be fitted. Rear lens doesn't though. Rear frame grill can be left off ( usually covered by race seat anyway)
The Aprilia hoses would be too big I think for a 30mm carb......
mickdale
thanks paul
the motor im getting wouldnt make group 4 but want the scoot to be in compliance as i might think about it
suppose it would have to be "street class" or "6"
paulmgreen
Street Class is the easiest way to get on track and actually in some ways te most open class as far as modifications goes.
GP Kevo
Are these basically the same as a velocity stack?
mickdale
they are just a plastic / rubber hose shape, like a bellmouth but straight without a cone profile
i believe they smooth out the carburation
GP Kevo
I see. Are velocity stacks legal? Some of you guys not wanting to go the air filter route might be interested in these.
    Users browsing this forum: Google [Bot] and 11 guests
