Stripped Exhaust Thread
Posted: Sat Aug 11, 2012 8:22 am
by Tom Russell
A mate has stripped exhaust thread on his Mugello barrel
What's the best type of thread repair kit to use in this area (lots of heat!), helicoil, timesert etc.
Be good to hear feedback from someone whose done similar repair, that held!
Thanks,
Tom
Re: Stripped Exhaust Thread
Posted: Sat Aug 11, 2012 8:30 am
by tavspeed
i haved drilled the hole out 7mm and re-tapped it m8,make sure you use a plug tap to finish the hole off,to get maximum thread area,
also you can use a readily available m8 allen bolt head screw,and drill the head for lock wiring,these are cheap and readily available,
not like the m7 ones sold on ebay at extortionate prices,hope this helps,cheers all.
Posted: Sat Aug 11, 2012 9:22 am
by storkfoot
Retapped mine m8 and got a precision engineers to machine m8 stud one end and m7 on other end. I think, actually, a dealer out there, maybe beedspeed sells such studs.
Posted: Sat Aug 11, 2012 9:42 am
by tavspeed
think you can get oversized studs,or just drill out the exhaust stub flange 8mm,give the drill a wiggle and should take a m8 thread with a nice tight fit.
Posted: Sun Aug 12, 2012 8:37 am
by Toddy
storkfoot wrote:Retapped mine m8 and got a precision engineers to machine m8 stud one end and m7 on other end. I think, actually, a dealer out there, maybe beedspeed sells such studs.
Yes beedspeed do sell them
I needed one a few weeks ago
Posted: Sun Aug 12, 2012 12:01 pm
by Tom Russell
Thanks everyone for your replys; this now gives me some different options to work with
I've heard the Mugello cylinders are particularly prone to this thread stripping problem, so anyone like to comment, or is this just pub talk?!?!
Posted: Sun Aug 12, 2012 12:18 pm
by bristolmod
I don't think its just Muggies- any alloy cylinder is going to be more prone to this problem than a cast iron cylinder
