Petrol Tank Leak
Posted: Sat Aug 11, 2012 7:38 am
by dopeshots
Hi all, I understand you can buy something to stop tanks leaking? I've just fitted a long range tank but it has a slight leak n one of the seams.
Any recommendations please?
Cheers :fb:
Re: Petrol Tank Leak
Posted: Sat Aug 11, 2012 1:28 pm
by warts
If its not been used, would it be better to have it welded? By the place which supplied it? It could be fibreglass or secondhand I suppose. Recently discussed:
http://scooterotica.org/forum/viewtopic.php?f=6&t=22817
Posted: Sat Aug 11, 2012 2:55 pm
by RICSPEED
tbh .. i find tank seal to be a last resort solution .. if its new send it back .. second hand then far better to get it welded
Posted: Sun Aug 12, 2012 1:44 am
by shureimage
Posted: Sun Aug 12, 2012 5:25 am
by DigDug
As advised already get it welded it will only get worse.
I used this stuff that lasted for 18 months
http://www.creatrix.co/index.php?dispat ... oduct_id=3
Then I got it welded - same chap that supplied it - top fella did it FOC!
Posted: Sun Aug 12, 2012 8:34 am
by Toddy
I would weld as well , but if it's new I would return !
Posted: Sun Aug 12, 2012 8:45 am
by dopeshots
Cheers Guys, it is new so I'm gonna return it once my other one turns up. That will teach me to buy cheap off eBay!
Posted: Sun Aug 12, 2012 8:58 am
by Toddy
dopeshots wrote:Cheers Guys, it is new so I'm gonna return it once my other one turns up. That will teach me to buy cheap off eBay!
Good idea
Posted: Sun Aug 12, 2012 8:32 pm
by Baggy
Is it 1 of the stainless standard looking long range tanks? IE with the lip? I've seen a lot of these including my own, and all had cracks or some other defect. As others have already said, welding is the best permanent solution, preferably TIG.
All but 1 had cracks in the tank where the fuel tap thread is fitted. I took 1 back to a dealer only to be offered 2 more with the same defects, so I got a refund. I then bought a second hand 1 for half the price and repaired it.
