TS1225 - 33bhp
Posted: Fri Aug 10, 2012 9:10 am
by drunkmunkey6969
TS1 225 - Scooterotica ported cylinder
MB piston
Tassinari V-force Reeds
Franspeed Race Pipe
34mm Delly
6 plate Clutch
Li150 Gearbox 16/47
No welding or crankcase porting.
33.2bhp @ 8100rpm
23.5 ft-lbs @ 6900rpm
Might play with the pipe length on this one and adjust peak BHP up another 250-500rpm, should sit around 35bhp then.
Re: TS1225 - 33bhp
Posted: Fri Aug 10, 2012 10:27 am
by Darrell Taylor
well done dan good result
is this the one you put pics up of recently,what stroke/rod is it
Re: TS1225 - 33bhp
Posted: Fri Aug 10, 2012 10:57 am
by Stokie
A little cheaper than a Super Monza too I guess?
Re: TS1225 - 33bhp
Posted: Fri Aug 10, 2012 11:06 am
by Andy Pickering
Im guessing its the yellow peril ??
Re: TS1225 - 33bhp
Posted: Fri Aug 10, 2012 4:49 pm
by drunkmunkey6969
Darrell - no, not posted pics of this particular cylinder etc yet.
Stokie - Aye, it worked out a bit cheaper on this project....lol.
Andy - sort of, its a long story....various engines are currently being built, swapped, changed etc....nothing stays the same for too long.
Re: TS1225 - 33bhp
Posted: Fri Aug 10, 2012 7:42 pm
by Muppet
have you tried the same tune with a smaller carb just out of interest,
muppet,
Re: TS1225 - 33bhp
Posted: Sun Aug 12, 2012 10:20 pm
by drunkmunkey6969
Muppet wrote:have you tried the same tune with a smaller carb just out of interest,
muppet,
Not yet, but will try a 30mm phbh eventually.
