Exhausts.........again!
Posted: Wed Aug 08, 2012 4:05 pm
My bike / set up: ts1225, sx200 gear box, 15 x 46 sprockets & nk rally pipe.
This is all ok up to a point, pulls well through the gears etc, but I think it seems quite revvy even when only doing 55-60mph in top.
I used to run with a mk1 fresco, & it didn't seem to feel like I was thrashing it at even 65-70mph. I swapped it cos I didn't particularly like the look or sound of the fresco, thinking it's a bit dated.
Now truth be told, i'm not particularly fussed these days whether my scoot would only do 70mph flat out as I simply don't ride that fast anymore, & generally travel in small groups sat at between 55-60mph whereby you tend to stick together-ish, & are therefore only as good as the slowest bike.
Am I right in thinking, that by changing to either a Taffy mk4, jl3 or ads3 that I'd still get the good torque throughout the range, but that my bike wouldn't sound like it's working as hard when in 4th doing 60mph, or is that a bit simplistic?
BTW I'ts defo an nk 'rally' as opposed to 'race' as i've checked my receipt & rung AF to confirm.
Also Dan 'drunkmunkey'? I hear what you've said previously re the Franspeed race, but as you can see i'm not trying to achieve great speed or a massive amount of revvs. However, if it is as good as the aforementioned pipes low down, then i'd consider it.
Thanks.
Thanks.
