RACING INLET RUBBER
Posted: Sat Aug 04, 2012 9:24 pm
by mickdale
what is the "bellmouth" style rubber/plastic inlet thats used on the carbs for racing
is it off a gillera?
anyone know the diameter?
assume its ok to cut a hole in the panel on group 4
cheers
mick
Re: RACING INLET RUBBER
Posted: Sun Aug 05, 2012 7:09 pm
by wack 63
Got one on the Team DKS group 4 but not sure what it is off,try ringing Chalkie at Replay . Image
Posted: Sun Aug 05, 2012 9:15 pm
by paulmgreen
Commonly used ones re from an Aprilia..... As above Chalky at Replay will sort you out . What carb are you running?
Posted: Sun Aug 05, 2012 9:51 pm
by mickdale
hello paul
30mm vhsh carb at the mo but will probably change
sorry to ask a stupid question:
regs say no modifications to headset but assume its ok to cut a hole in the panel for group 4 and cut the rear runner a bit for brake pedal in non stanard position
also ok not to use rear frame grille and rear light housing - if this is ok is it ok not to run hornacst grille?
cheers
mick
Posted: Sun Aug 05, 2012 11:06 pm
by paulmgreen
I assume you are talking about Gp 4 ?...
Holes to suit carb are ok in side panels.... As are for rear set.... They can't be huge though .... Just enough for clearance !
The real light housing and horn casing grill need to be fitted. Rear lens doesn't though. Rear frame grill can be left off ( usually covered by race seat anyway)
The Aprilia hoses would be too big I think for a 30mm carb......
Posted: Mon Aug 06, 2012 7:30 am
by mickdale
thanks paul
the motor im getting wouldnt make group 4 but want the scoot to be in compliance as i might think about it
suppose it would have to be "street class" or "6"
Posted: Mon Aug 06, 2012 10:00 pm
by paulmgreen
Street Class is the easiest way to get on track and actually in some ways te most open class as far as modifications goes.
Posted: Tue Aug 07, 2012 8:42 am
by GP Kevo
Are these basically the same as a velocity stack?
Posted: Tue Aug 07, 2012 11:21 am
by mickdale
they are just a plastic / rubber hose shape, like a bellmouth but straight without a cone profile
i believe they smooth out the carburation
Posted: Sun Aug 12, 2012 5:25 pm
by GP Kevo
I see. Are velocity stacks legal? Some of you guys not wanting to go the air filter route might be interested in these.
