Exhaust question.
Posted: Thu Aug 02, 2012 12:49 pm
by Fux
I`ve got a Mk.1 GS with a SS180 engine.
The engine has had a full overhual and been converted to 12v leccy. It goes realy well but these repro pipes are a bag of poo.
Am I correct in thinking that if a fit one of these
http://www.sip-scootershop.com/en/produ ... d_13014380, I can use any p200 pipe?
If so, which pipe would you fellas reccomend? Prefrably torque over revs.
Cheers,
Rob
Re: Exhaust question.
Posted: Thu Aug 02, 2012 2:01 pm
by cit205
If you want something subtle but which works well especially for torque i would say one of sip's semi expansions
http://www.sip-scootershop.com/en/produ ... r_24165000
You will still have to do some modifications to the swing arm bracket part of any p-range exhaust to fit it to your SS engine though, even with that stub it won't be going straight on ,says as much in the write up in your link.
Posted: Fri Aug 03, 2012 10:50 am
by Fux
Ok cheers.
I have a 120 main jet, any idea as to how high I will need to go on that?
Posted: Fri Aug 03, 2012 11:28 am
by cit205
Jetting's trial and error obviously ,but as a guide i only needed to go up one on my rally 200 when i fitted one so it runs a 120 now , you have a different engine and carb but going on that you'd probably need a 122 at a guess .
Posted: Fri Aug 03, 2012 11:54 pm
by Fux
Cheers. I`ll go up a few and work my way down to a couple.
Posted: Sat Aug 04, 2012 9:23 am
by Svint1
Hi Rob,
There are exhaust-conversion kits available for the SS/GS engines.
Just change the exhaust stub on the cylinder, and any PX200 pipe will fit.
Would highly recomend the SIP Road exhaust...
Ø
