Page 1 of 2
Billet Links
Posted: Mon Jul 30, 2012 11:31 pm
by gpts1
Some new links I've made for my next project
These are the first set made, and I may make another set.
Re: Billet Links
Posted: Mon Jul 30, 2012 11:43 pm
by Muttley McLadd
Is the top one from ScootRS, for comparison?
gpts1 wrote: Image
Re: Billet Links
Posted: Tue Jul 31, 2012 6:24 am
by Toddy
Very nice them mate were they expensive to do?
Billet Links
Posted: Tue Jul 31, 2012 6:30 am
by soulsurfer
Is there a custom wheel going between the links as I don't see any offset?
Re: Billet Links
Posted: Tue Jul 31, 2012 8:40 am
by gpts1
soulsurfer wrote:Is there a custom wheel going between the links as I don't see any offset?
Doesnt show well in the photo's but there the same as stock, just used a stock drum link as the base and as you can see in the photos have added extra ribbing allong the bottom to add strength and rigidaty,Have a SSC double disk to mount in between.
Re: Billet Links
Posted: Tue Jul 31, 2012 9:49 am
by tonydevon
nice work, Im doing something similar but waterjet cut from steel, as Im running all custom wheel and brake setup couple of questions
what are them shocks, they look so nice
and not being funny, but with all that work, is there a simple reason why you left the axle slot open, I have designed and planned to have mine as a hole not a slot. I realise its obviously safe as there so many scooters with the slot, but I just cant accept it LOL
Re: Billet Links
Posted: Tue Jul 31, 2012 10:00 am
by gpts1
front shocks are FOX Vanilla downhill mountin bike, had new springs made for them and they still need to be sent out to have lighter oil put in them. very high quality shock about $1000 NZ new, picked these up for half that as they were an older model.stock links work fine with the slot, i didnt see a need to change it just makes changing the front tire harder.
Re: Billet Links
Posted: Tue Jul 31, 2012 10:19 am
by tonydevon
cool, I was wondering about the spring rates, never seen softer than about 250lb on them shocks.
yeah I appreciate nothing wrong with the slot, just that I build bikes normally and it seemed really strange to me, but as you say must be easier for changes.
nice work on the links, will you run a crush tube twixt the bearings?
Re: Billet Links
Posted: Tue Jul 31, 2012 3:24 pm
by rapido230
very nice indeed
Re: Billet Links
Posted: Tue Jul 31, 2012 11:29 pm
by gpts1
tonydevon wrote:cool, I was wondering about the spring rates, never seen softer than about 250lb on them shocks.
Will probably put a spacer between the bearings and looks like i will need some small spacers each side of the bearings.
