No tail light, side light or speedo light!!
Posted: Mon Jul 30, 2012 9:51 pm
Need some more leccy help! Thought I had everything sort, engine was running lovely then I tried the lights :wtf:
First off they were all working, then I realised the engine would not turn off, turns out I had put one of the greens above the black from the ignition (where the speed bulb now is).
Re-wired it as per photo after looking at various diagrams.
Now, main light (dipped and full beam) is ok, but no tail, side or speedo light.
I have taken the power for the horn (working fine) from a spur by the headset that also spurs for the front brake (front brake and back brake fine but think they may be lighting both elements in the bulb).
Earths all look ok.
Any ideas appreciated as I'm about two hours from getting it on the road if I can sort this out.
Earths all look ok.
