surging when slowing down
Posted: Mon Jul 30, 2012 9:03 pm
had just run my 225 rapido in prior to going to Weston at the weekend,so hadn't really given it any abuse prior to that.I'm a A road user more than motorway (by choice anyway unless I have to) so most of the time at 50-55 mph,scoot goes fine.When I was on a few stretches of dual carriageway opened it up to about 65 and when I closed the throttle it surges.The set up is:
static electronic ignition 16 degrees strobed
48 mm clubman
delly 30 open mouth -tea strainer filter -hole in panel with mesh
main jet 122
idle 55
X7 second clip
300 float jet
AV266
mixture 3 turns out
Did have a 125 main jet in whilst running in,but bogged a bit when the throttle went onto the main so dropped to a 122 and its a lot crisper.The barrel has had 1.5mm taken off the bottom of the base gasket face and the inlet/outlet ports matched.plug is colour OK if not a little on the rich side.I'm wondering is it too lean as the revs drop,definitely don't get the pop pop pop from the exhaust.Tried it with a AV264 and X13 in various positions,didn't run very well.Its a very torquey motor so changing it to a 16X46 over the weekend.Any info much appreciated ,there is a thread on the LCGB forum but to no significant outcome..the only info I can find is this off the old MB site "Main jet Adjustment Whilst Running In
.http://www.mbdevelopments.co.uk/archive/mag42.html
A classic example of a weak main jet is when you are flat out and you shut off to slow down, or change gear, if your motor actually speeds up (not to be confused with clutch slip!) then increase the main jet.
48 mm clubman
main jet 122
idle 55
X7 second clip
300 float jet
AV266
mixture 3 turns out
