28mm dellorto jet set up
mattyp
Main scooter: Lambretta winter model
I plan to put a 28mm dellorto on a li 150 engine with a 200 kit on it and a clubman exhaust. What set up do i need in the carb?
Special X
start with
52 pilot
45 slide (don't worry the 40 will do for now)
AV266 atomiser
X7 needle 2nd clip
115 main
Should be safe and within the ballpark.
mattyp
thanks ill give that a go
