Carb ??
Posted: Sun Jul 22, 2012 3:41 pm
by mickymidas
The answer be posted elsewhere on here but cant find it.
P200 in Rally frame ....will start and tick over ok , but when thottle applied it dies ..Dellorto 24/24 E....160AC, B3, 120 main.
Have tried 2 other float & needles, all the same effect...am i missing something ?...Gaskets maybe ?
Re: Carb ??
Posted: Sun Jul 22, 2012 8:41 pm
by wack 63
Remove the air filter and look down the carb bore when you rev the scoot,you should see fuel come out of the brass tube that sticks out into the bore.If nothing comes out then it is possible the drillings from the main jet is blocked or the jet is, so remove the atomiser and squirt WD40 or similar down the hole to check the flow.
Re: Carb ??
Posted: Sun Jul 22, 2012 9:41 pm
by mickymidas
Cheers wack will try that ......
