RAPPIDO 225 CLASSIC CARB SET UP
Posted: Sun Jul 22, 2012 3:05 pm
by mattyp
I have a rappido classic 225, with a sterling exhaust and a 30mm delorto. Please could you tell me the set up for the carb.
Re: RAPPIDO 225 CLASSIC CARB SET UP
Posted: Sun Jul 22, 2012 5:13 pm
by col68
Now mate i had that set up but a jl3 pipe 55 idle, 40 slide, av266, x7 clip on 2nd from bottom , 128-130 main. If scoot stutters with 130 flat out try 128 main cant be far off check plug colour should be a nice chock brown . Had a ram air filter on :fb:
Posted: Sun Jul 22, 2012 6:58 pm
by mattyp
thanks, i have just ordered that set up
Posted: Sun Jul 22, 2012 7:33 pm
by tony81
i have same set up 40 slide 70choke 55idle x7 needle (second clip down from top)av266 122main runs very nice also try open mouth carb then put a filter on filter slightly slows it down.
Posted: Mon Jul 23, 2012 7:14 am
by dsc scotty
Also use a 300 fuel needle valve!
Posted: Mon Jul 23, 2012 8:09 am
by DaveTomo
tony81 wrote:i have same set up 40 slide 70choke 55idle x7 needle (second clip down from top)av266 122main runs very nice also try open mouth carb then put a filter on filter slightly slows it down.
+1,tried a 125 main bogged slightly so have dropped down to a 122
