My new project
Posted: Sat Jul 21, 2012 1:08 am
Heres a few pics of my new project, and maybe next years rally ride.
I brought it from a friend who crashed it on the way to the euro in Ireland last year (read last months "into the sunset" in scootering)
Snapped headset
Back pushed in
bent forks
and frame tube
So it was stripped and blasted, the frame went to Grand sport for straightening. They dont straighten fork so i did them my self with the aid of a scaffold bar, an immoveable object and a straight edge, and a good (hopefully
) eye . Ill have to see how it rides ?
I brought a headset top of a friend of a friend so i could get the headset lined up and welded
So now im on with the body work and painting. The sand blasting revealed the leggies and front mudguard had seen better days
so after an hour or so of panel beating a bit of welding, acid etch primer, then filling and sanding, more panel beating , more filling and sanding more primer, more filler, more sanding, high build primer, stopper, more sanding,
and then some paint
more sanding
This is were i am at the moment
more to follow
Snapped headset
Back pushed in
and then some paint
more to follow
