RB 250 Set Up
Posted: Thu Jul 19, 2012 3:02 pm
by Lamaddict
Gearing - I've already got a standard Li125 gearbox, later type which I'd like to possibily use, just because I've got one in the garage. I can get to 4.6-4.8 with the sprokets but any comments on how it may perform?
Crank - I've already got a 58 SIL webbed 110 Yam rod which I'd like to use with packers to get it all lined up, any comments?
Piston and head - I'm thinking of an MB Racetour piston and cylinder head to suit?
Re: RB 250 Set Up
Posted: Thu Jul 19, 2012 4:00 pm
by Yanker
Hi, the 250 is designed arround 60mm stroke crank. you would need to use the port timing calculator to see if you can get desired/reasonable timings with that crank, using the port heights in the barrel.
The RB 250 piston is forged with 1mm wire rings: therefor the same spec as the MB pistons.
AF do a selection of heads with different compression ratios for this kit.
Re: RB 250 Set Up
Posted: Fri Jul 20, 2012 2:56 pm
by Lamaddict
Yes I'll be knocking the CC's down.
I didn't realise AF offered head options. Thinking back I think MB and AF have had differing views on cylinder heads?
RB 250 Set Up
Posted: Fri Jul 20, 2012 2:58 pm
by jonashford
Afs are testing the Avanti head on the rb at the moment
Re: RB 250 Set Up
Posted: Tue Jul 24, 2012 10:34 pm
by Terrible Taff
Lamaddict wrote:Yes I'll be knocking the CC's down.
At Taffspeed I have used the 10.5 high comp head AF option then machined it so no head gasket is used & dowelled central with the squish 1.5mm recessed into the head.
I have used 5.8 to 1 corrected compression ratio.
This allows for the use of 95 octane unleaded With 4% oil mix to keep the crank lubed.
17' btdc ignition advance, Franspeed JL race exhaust, 34mm Dellorto VHSB.
BR8ES or 240 degree C heat range spark plug this gapped @ 0.020" (0.5mm)
Gearing set for 80mph max sitting upright solo riding so that the scooter performs over a wide speed range.
The RB250's that I have built up are all over 30bhp @ rear wheel 21 ft/lbs torque @ 7,000 rpm.
Hope this info has helped those tuning their RB motors!
Regards
Ian Frankland
Taffspeed
07794 003276
