Old type hydraulic disc brake
Posted: Wed Apr 15, 2009 7:27 pm
by celt
Re: Old type hydraulic disc brake
Posted: Wed Apr 15, 2009 10:19 pm
by Knowledge
The piston in the slave may have been manufactured, rather than sourced from a motorcycle. Mine was made by Kev Braithwaite (long before TWE) and it was custom built.
It would be worth checking the other aspects of the brake. Is the disc loose on its dowels when the caliper is out of position?
Is the static pad correctly adjusted? The disc might be rubbing on the ali that supports the static pad, giving the impression of binding.
Just a thought.
Posted: Wed Apr 15, 2009 10:29 pm
by J1MS
looks like a Sukuki piston out of a GT 250 or similar....I Might be wrong........ Martin from Chiselspeed's did a conversion similar to this, and that piston looks like the one he used, Suzuki 250.....
Posted: Wed Apr 15, 2009 10:30 pm
by sean brady scooters
i agree that your best bet would be to talk to martin at chiselspeed...............
Posted: Wed Apr 15, 2009 10:35 pm
by DACTEK
Take the kink out of the hose as i may stop the fluid from retuning to the master. Also never the grease seals just rub some fluid around them. Is that the o ring type? If so you can get them from anywhere.
Posted: Wed Apr 15, 2009 11:18 pm
by Andy Pickering
It does look like a GT250.although they used this set up on the X7 and others, to be honest the piston looks worn and would invest in a new one.
