Fitting a reed valve to rapido
Posted: Sun Jul 15, 2012 11:52 am
hi im fitting a reed valve to my rapido 225 where do i put and how long for boost port thanks
It needs to run up from the inlet port and finish level with the top of the transfers somewhere around 22 - 25 mm wide but check where the ring pegs are. The depth will depend on the amoununt of metal you have to play with. When I cut mine into an SR 225 type barrel i managed to break through to the outside between the finsharpo wrote:hi im fitting a reed valve to my rapido 225 where do i put and how long for boost port thanks
It says that album doesn'y existwack 63 wrote:Have a look thru these http://www.lambretta-images.com/archive ... play_media
Tried it again, still getting....... Error The selected album/file does not exist!wack 63 wrote:Just worked for me?
