rb250 Dellorto settings
Posted: Wed Apr 15, 2009 3:32 pm
by AndyS
Is anyone running an RB 250 with a Dellorto 34mm fitted.
I have jetted it as per AF's spec sheet but it is really boggy up to 1/2 throttle.
Setings are
K21 needle
DP267 atomiser
Main 198 ( but have not actually got to this so far)
Pilot 55
Choke 60
Have tried a DQ266, it is slightly better, but still very boggy.
The gearing is SX200 with 16x46 sprockets ( 4.5)
Exhaust is franspeed tourer.
Due to runnig it in I cant go above 55 mph for a while, and with the gearing the throttle is only about 1/3 open.
Any help would be appreciated
Re: rb250 Dellorto settings
Posted: Wed Apr 15, 2009 10:27 pm
by Knowledge
I agree that you should not have hit the main jet circuit yet, but that main jet seems huge. Why not just try a 160 just to see.
What have you got to lose for the sake of a quick blatt up the road.
Also, check that the choke is closing properly, as it might be open all the time. Have a look down the mouth of the carb and you should be able to see the plunger.
Finally, have you adjusted the air screw?
Posted: Wed Apr 15, 2009 11:23 pm
by J1MS
Why not fit the 15x46 while you run it in, then switch back later......Got to agree with Knowledge the main jet does seem big...
Posted: Thu Apr 16, 2009 11:29 am
by AndyS
The main is what is recomended by AF.
I thought it maight have been the choke, so disconected it, but it was still the same.
I dont think that there are many about a the moment, if a few people have them you can compare jetting and generally get it a bit nearer.
Might go down the Mikuni route, had one last year on my RB225 and it was fantastic.
Posted: Sun Apr 19, 2009 10:50 pm
by andyC
hi my rb25 runs
40-slide
k24-needle 2nd clip
dp267-atomiser
195-main jet
45-pilot
60-choke
300-float valve
gp 200 gears/19-46 sprockets
varitronic 25 degrees initial advance
runs clean thru all the gears
hope this helps
Posted: Mon Apr 20, 2009 6:49 pm
by AndyS
I think I have sorted it now. It was probably a combination of thgings.
I cut and remade the choke cable so that I am sure it isnt open when running.
There is an inlet on the side othe carb, which I think is for an oil injection, this wasn't blocked, it is now, have dropped the pilot to 45.
I now need to try a DQ267 atomiser as I have a DQ266 on it at the moment and I think that it will be lean in the mid range.
Thanks for posting your findings
I think I maight change the gear ratio aswell, it pulls 4.5 but it struggles a bit if I am not revving it up hill
Posted: Wed Aug 03, 2011 12:02 pm
by Bilko
How are you getting on with this?
I've the same set initial set up as you and boggy as f@@k up to half. After that it's too lean.
Struggling to find an answer
