Scootrs pipe on Imola keeps coming loose !!!
Posted: Mon Jul 02, 2012 5:10 pm
by nellyboyo
HIya all, I`ve wire locked the nuts, I`ve fitted new rubbers so the body of the pipe floats on them , I`ve loctite`d the studs in place . All nuts fitted with a flat and a spring washer. The pipe does not rub anywhere. What seems to be happening after a 20 mile run is the barrel studs are winding themselves out into the nuts ? ? I just nipped them up in place with loctite, didn`t bottom them out
Its driving me mad.
That`s 4 times now I`ve had it on and off
Any other ideas welcome, would prefer a stub type exhaust in the future but I know others who run these on an Imola , no probs
Re: Scootrs pipe on Imola keeps coming loose !!!
Posted: Tue Jul 03, 2012 12:11 am
by tony
Are they stainless studs mate? Also... what loctite are you using? Loctite comes in different strengths for different purposes. You can get higher melt point temp loctites basically.
Posted: Tue Jul 03, 2012 8:10 am
by nellyboyo
They are normal mild steel studs mate and I`m using studlock.
If it comes loose again I think I`ll put the taffspeed copy I`ve`got on my s2 on it . Need the imola type stub though , gave one away in the past ....DOH!!
Posted: Thu Jul 05, 2012 4:52 pm
by GP Kevo
Maybe the flange on the exhaust is warped. It was on mine.
Posted: Thu Jul 05, 2012 10:11 pm
by nellyboyo
Cheers I`ll check that next time it next time it comes off.
Posted: Fri Jul 06, 2012 1:54 pm
by Adam_Winstone
"but I know others who run these on an Imola , no probs".... yet!
Posted: Thu Jul 12, 2012 1:51 am
by Bombay Mix Pilot
My stainless Scoot RS pipe came loose and leaked a couple of times so when I fitted a new Rapido engine I locktited the studs etc but also had a looked at the flange and found it was not flat faced, so I lapped it in with wet 'n' dry on a piece of glass, so far so good almost 1500 miles of running in with no problems, touch wood !!! Hope this helps.
Andy
