NU205/NU2205
CPH Lambretta
Main scooter: DL 150 1970
I ordered a flywheel bearing for my DL150 ,when it arrived I fitted the bearing track to my original crank.
Now I realize that the bearing was a NU2205 not a NU205 (that is normally fitted to the DL150).
Question is can I use the NU 2205 bearing on the 150 crank? Maybe if I leave out the spacer in the mag housing?
Any help much appreciated,cheers Nick
Slow is the new fast!
Muppet
bearing fits in mag without the spacer; track fits on the crank but is 4mm longer than the one it replaces; your crank has a 14mm shoulder the 200 crank has a 10mm shoulder; does it fit the answer is yes and no,
muppet,
C’est la vie
CPH Lambretta
thanks for your answer Muppet, so what your saying is the bearing parts will fit individually (on crank/in mag housing) but when fitted in the engine the bearing won't run centrally on the track?
    Users browsing this forum: Amazon [Bot], Google Adsense [Bot] and 2 guests
