Page 1 of 2
JL3 rubber sleeve
Posted: Mon Jul 02, 2012 4:50 pm
by newmanlammy
Who sell the new rubber sleeves that were brought out recently to stop oil spitting out of the rear slip joint on JL3 pipes, I can find them on ebay but they come to about £14 with postage. Sure i've seen them advertised somewhere for about £7.
JL3 rubber sleeve
Posted: Mon Jul 02, 2012 6:21 pm
by jonny wadd
Readspeed sell them
Re: JL3 rubber sleeve
Posted: Mon Jul 02, 2012 10:22 pm
by molibdimum
http://www.ekmpowershop2.com/ekmps/shop ... 5159-p.asp
Can someone explain this bit to me?
THE RUBBER HELPS TO REDUCE EXCESS 2 STROKE OIL IF THE EXHAUST RUNS SLIGHTLY RICH
Posted: Tue Jul 03, 2012 9:15 am
by handofdave
just use some high temp silicone on assembly and it stops the leak no rubber needed
Posted: Tue Jul 03, 2012 10:46 am
by Craig H
You could try heat shrink?
Posted: Tue Jul 03, 2012 6:00 pm
by Skar
Cut up a mountain bike inner tube.
Posted: Tue Jul 03, 2012 10:15 pm
by Bren
I use a bit of car radiator hose. Works a treat..!
Posted: Wed Jul 04, 2012 8:50 pm
by corrado
You need one that has different sizes at either end. The tube on the silencer part is smaller than the main pipe it fits into.
Posted: Wed Jul 04, 2012 9:44 pm
by newmanlammy
Just ordered some high temp silicon hose reducers with the correct diemeters to try, will post pics if they fit ok
Posted: Wed Jul 04, 2012 11:45 pm
by coaster
handofdave wrote:just use some high temp silicone on assembly and it stops the leak no rubber needed
Ditto, works for me too 8-)
