trouble over 60
Posted: Sat Jun 30, 2012 7:45 pm
by woody69
any 1 any ideas,got mugello 225 30 delorto,started spluttering over 60 and dieing ,when u shut throttle and sit aat 55 al ok,i clean carb out ,changed fuel tap and still doing it :wtf: any ideas
Re: trouble over 60
Posted: Sun Jul 01, 2012 10:20 am
by woody69
no only seems to do it in 4th
:wtf:
Re: trouble over 60
Posted: Sun Jul 01, 2012 11:14 am
by nelson pk
If it has been running for quite a while without problems and just started doing it, i would go with eden and say electrical and try a different stator or CDI unit. Could just be doing it in fourth as it will put a bigger load on the engine in fourth gear.
Only other thing to check on your fuel system is a worn needle valve but it would probably do it in all ranges if this was the case.
Re: trouble over 60
Posted: Sun Jul 01, 2012 8:50 pm
by Lamaddict
Too rich main jet?
