Backfire?
Posted: Wed Jun 27, 2012 11:19 pm
by des
I just put a 200 engine into one of my scoots, 12v electronic ign, 22mm dellorto, clubman exhaust, cant remember what timing i set it to as i built the engine over a year ago
When i kick it over it fires over and the kickstart kicks up hard, it keeps doing this till it eventually starts, is this a timing issue and if so what should the timing be 19 or 21 deg for a sil 200cc stage 4 barrell.
Re: Backfire?
Posted: Thu Jun 28, 2012 6:39 am
by Toddy
des wrote:I just put a 200 engine into one of my scoots, 12v electronic ign, 22mm dellorto, clubman exhaust, cant remember what timing i set it to as i built the engine over a year ago
I would set at 19 , when you say kickstart kicks back up do you mean like normal compression wise? its not catching on something inside ?
Re: Backfire?
Posted: Thu Jun 28, 2012 9:27 am
by des
Its not catching on anything when i kick it over it starts up when the kickstarter is half way down and then kind off back fires and kicks the kickstarter back up
Re: Backfire?
Posted: Thu Jun 28, 2012 2:37 pm
by bristolmod
over advanced timing- engine is "kicking back".
