Page 1 of 2
What sprockets on an Imola?
Posted: Wed Jun 27, 2012 1:59 pm
by 10 inch Terror
Hi all, I have asked a question on someone else's thread concerning my imola engine. I'm currently running it on a 30mm Delly, Ducati light flywheel, JL 3 / Franspeed pipe, AF 47 tooth clutch, 16 tooth front sprocket with Italian LI150 box. This gives a final drive of 5.0. The bike goes really well in 1,2 and 3 but just dies in 4th. Someone has recomended I go 46 / 15 sprocket wise. The thing is at almost £500 I don't want to ditch the AF clutch, is there any other options to try and improve the top end and keep the clutch i already have? Thanks in advance Pete.
Re: What sprockets on an Imola?
Posted: Wed Jun 27, 2012 2:06 pm
by corrado
15 x 47 gives 5.33. Needs a streched 80 link chain or an 81 with a pull down tensioner. That's a theoretical 77 mph at 8,000 rpm though the JL3 might not get that high.
Avantone's gearbox visualiser is what you need to play with.
Posted: Wed Jun 27, 2012 4:08 pm
by soullad
wise words from fecker Martin .. I ended up at 5.4 with my Imola after a whole raft of exhausts and carbs / inlets / reedblocks etc. Personally the kit really came alive when paired with a 30mm carb and a revvy exhaust ... behaved just like a TS1 200 then.
Posted: Wed Jun 27, 2012 4:23 pm
by rbgaz
hi try a 90/90 rear on it if works u can go on tonys gearbox app an work out u final drive
Posted: Wed Jun 27, 2012 5:01 pm
by 10 inch Terror
rbgaz wrote:hi try a 90/90 rear on it if works u can go on tonys gearbox app an work out u final drive
Hi, I've got a 90/90 tyre on the rear. So I'm I right in thinking that a JL race may suit the Imola better than the JL3? I think I'll try a 15 front sproket pull down tentioner and 81 link chain before I change the pipe. Thanks very much guys really appreciate you're comments and advice. Pete.
Posted: Wed Jun 27, 2012 5:27 pm
by rbgaz
i think u find it b worse with the race pipe they make the power high up the rev range
Posted: Wed Jun 27, 2012 5:28 pm
by psychedelicropcircle
I'd try the 15/47 cheaper, mines works really well on a jl curly....you can get them from that EX fecker corrado :freak:
Posted: Wed Jun 27, 2012 5:31 pm
by 10 inch Terror
Cheers chaps, I'll try changing the sprockets 1st and take it from there. Pete
Posted: Wed Jun 27, 2012 5:34 pm
The curly pipe gives all the power at the bottom to the extent I will be trying 16/46 and if I find it still being held back I'll then try 17/46, as it stands it runs out of gear before revs.
Posted: Thu Jun 28, 2012 3:35 pm
by corrado
psychedelicropcircle wrote: that EX fecker corrado :freak:
He's resting. He's shagged out after a long squawk. :frog:
