Halite washer ???
Posted: Sun Jun 24, 2012 12:03 am
by Bombay Mix Pilot
It's another one of those questions, Halite washer - what exactly is it's job ??? Just curious.
Thanks in advance of any info.
Andy.
Re: Halite washer ???
Posted: Sun Jun 24, 2012 8:50 am
by doggbhoy
to help keep the gear oil out of your pertol/2 stroke oil mix :)
Posted: Sun Jun 24, 2012 10:04 am
by bristolmod
the drive side oil seal is mounted on a plate (alloy, or preferably metal), which is screwed onto the crankcase with 4 small bolts.
The Hallite washer takes up (in theory), any imperfections between the oil seal plate and the crankcase itself, thus stopping your gear oil from flowing into the piston/ crank area
Posted: Sun Jun 24, 2012 10:23 am
by camel
the last build i did and the current one im doing ive used a 6305 with plastic seals in,obviously you need the flick out the one against the crank side and ive left out the hallite washer
Posted: Sun Jun 24, 2012 10:45 am
by bristolmod
camel wrote:the last build i did and the current one im doing ive used a 6305 with plastic seals in,obviously you need the flick out the one against the crank side and ive left out the hallite washer
As I'm a bit of a "belt and braces" bloke ( no it ain't a weird fetish), I'd certainly use that type of bearing but would leave the Hallite washer in as well.
Don't you mean you'd flick out the DRIVE side plastic??
Posted: Sun Jun 24, 2012 11:35 am
by camel
yes sorry.......i find that i cant get the hallite washer in as well as the plastic seal.....i guess its one or the other
Posted: Sun Jun 24, 2012 12:24 pm
by Bombay Mix Pilot
Thanks for the replies, any preference on how to lock the seal plate screws, dot punch or locktite ? I've got some of MBD's high tensile allen head screws to hold it in.
Andy
Posted: Sun Jun 24, 2012 12:55 pm
by bristolmod
a very small drop of a suitable Loctite product on clean threads.
Don't overdo it as you may need to remove them in the future!!
Posted: Sun Jun 24, 2012 2:21 pm
by tomdavid1988
I use the sealed bearings and always keep the halite washer, never had any probs doing this
